Introducción
This is ONLY a prerequisite guide to remove the LCD shield plate in the Motorola Cliq.
Qué necesitas
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
Turn the phone over and slide out the keyboard.
Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
Remove the ten 3.0 mm T4 Torx screws near the black display cable.
Una persona más ha completado esta guía.
