Saltar al contenido principal
Disassembling Midland X-tra Talk Radio LXT118 Speaker
Qué necesitas
  1. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: paso 1, imagen 1 de 2 Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: paso 1, imagen 2 de 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Speaker: paso 2, imagen 1 de 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Case: paso 3, imagen 1 de 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Speaker: paso 4, imagen 1 de 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Speaker: paso 5, imagen 1 de 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Disassembling Midland X-tra Talk Radio LXT118 Speaker: paso 6, imagen 1 de 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Disassembling Midland X-tra Talk Radio LXT118 Speaker: paso 7, imagen 1 de 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Disassembling Midland X-tra Talk Radio LXT118 Speaker: paso 8, imagen 1 de 1
    • The speaker is now disassembled!
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-43, Regan Winter 2013 Miembro de Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 579
