Saltar al contenido principal
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
Qué necesitas
  1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: paso 1, imagen 1 de 2 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: paso 1, imagen 2 de 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: paso 2, imagen 1 de 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: paso 3, imagen 1 de 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: paso 4, imagen 1 de 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: paso 5, imagen 1 de 1
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Conclusión
To reassemble your device, follow these instructions in reverse order, from step 6 to 1.
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-43, Regan Winter 2013 Miembro de Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 892
