Saltar al contenido principal
Disassembling Mercedes W123 Kick Panel
Qué necesitas
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: paso 1, imagen 1 de 1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: paso 2, imagen 1 de 1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: paso 3, imagen 1 de 2 Disassembling Mercedes W123 Kick Panel: paso 3, imagen 2 de 2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: paso 4, imagen 1 de 2 Disassembling Mercedes W123 Kick Panel: paso 4, imagen 2 de 2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: paso 5, imagen 1 de 3 Disassembling Mercedes W123 Kick Panel: paso 5, imagen 2 de 3 Disassembling Mercedes W123 Kick Panel: paso 5, imagen 3 de 3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
Conclusión
11 personas más completaron esta guía.
Nicolas Siemsen
Miembro Desde 12/06/13
39,010 Reputación
79 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,521 Guías creadas
Un comentario
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 56
Todo El Tiempo: 13,397
