Introducción
There are a lot of items behind the dash board of a W123 that may eventually need service, anything from various relays, to one of several vacuum actuators for the climate control vents and flaps.
One way to get easier access to several of these parts is to remove the glove box liner. Learn how here.
Partes
No se requieren partes.
  1. Start by opening the glove box.
    • Start by opening the glove box.
  2. Remove the two phillips screws in the glove box door catch, then remove it. Remove the two phillips screws in the glove box door catch, then remove it.
    • Remove the two phillips screws in the glove box door catch, then remove it.
  3. Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom. Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
    • Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom.
    • Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. You can then pry the clips out of the liner. Remove them all.
    • You can then pry the clips out of the liner. Remove them all.
  6. Gently pry down the cover for the glove box lamp.
    • Gently pry down the cover for the glove box lamp.
  7. Now unplug the two connections from the lamp and remove the lamp housing.
    • Now unplug the two connections from the lamp and remove the lamp housing.
    • Be sure to make note of the orientation of the two wires for re-installation.
  8. Now the glove box liner will pull out by hand.
    • Now the glove box liner will pull out by hand.
Conclusión
2 personas más completaron esta guía.
Nicolas Siemsen
Miembro Desde 06/12/13
29,971 Reputación
79 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
280 Miembros
783 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 77
Todo El Tiempo: 5,968
