Saltar al contenido principal
Disassembling Marshall MS-2 Partner Circuit Board
Qué necesitas
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: paso 1, imagen 1 de 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: paso 2, imagen 1 de 3 Disassembling Marshall MS-2 Partner Circuit Board: paso 2, imagen 2 de 3 Disassembling Marshall MS-2 Partner Circuit Board: paso 2, imagen 3 de 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: paso 3, imagen 1 de 2 Disassembling Marshall MS-2 Partner Circuit Board: paso 3, imagen 2 de 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: paso 4, imagen 1 de 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: paso 5, imagen 1 de 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: paso 5, imagen 2 de 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: paso 6, imagen 1 de 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: paso 7, imagen 1 de 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
Conclusión
3 personas más completaron esta guía.
Un comentario
There Is a toroidal transformer inside ?
Jack redmond - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,889
