Saltar al contenido principal
Disassembling Macintosh IIsi Floppy Drive
Qué necesitas
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: paso 1, imagen 1 de 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: paso 1, imagen 2 de 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: paso 2, imagen 1 de 3 Disassembling Macintosh IIsi Floppy Drive: paso 2, imagen 2 de 3 Disassembling Macintosh IIsi Floppy Drive: paso 2, imagen 3 de 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: paso 3, imagen 1 de 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: paso 3, imagen 2 de 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: paso 3, imagen 3 de 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: paso 4, imagen 1 de 3 Disassembling Macintosh IIsi Floppy Drive: paso 4, imagen 2 de 3 Disassembling Macintosh IIsi Floppy Drive: paso 4, imagen 3 de 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Conclusión
2 personas más completaron esta guía.
Chris Green
Miembro Desde 10/11/09
36,978 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,532 Guías creadas
Un comentario
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,760
