Qué necesitas
The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
2Guía Comentarios
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
