Saltar al contenido principal
Disassembling LG 440G Rear casing
Qué necesitas
  1. Disassembling LG 440G Rear casing, Turn off phone.: paso 1, imagen 1 de 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: paso 2, imagen 1 de 1
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: paso 3, imagen 1 de 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: paso 4, imagen 1 de 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: paso 5, imagen 1 de 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: paso 6, imagen 1 de 2 Disassembling LG 440G Rear casing, Lift casing cover: paso 6, imagen 2 de 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Conclusión
Emily Class
Miembro Desde 02/17/15
107 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-1, Buehl Winter 2015 Miembro de Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Miembros
8 Guías creadas
Un comentario
this would be most probably, the same guide to tear down the LG B470
douglas flores - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,686
