Introducción
The espresso machine lid may leak, or you may need to service the electrical components. Follow the steps to remove the top plastic cover of the espresso unit in order to solve these problems:
1.) silicone washer attached to the inside top of the lid can fall into the unit (retrieve & press back into lid), resulting in the lid leaking;
2.) part of the silicone O-ring at the base of the threads is pushed under the machine top plastic cover, no longer protecting the inside of the unit from excess water entering the machine through the hole in the top section of the plastic cover.
Qué necesitas
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Remove the three 60mm Phillips size 0 screws holding the top cover on.
Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
3 personas más completaron esta guía.
