Saltar al contenido principal
Disassembling Kodak Easyshare C813 Front Cover
Qué necesitas
  1. Disassembling Kodak Easyshare C813 Front Cover, Battery: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Front Cover: paso 2, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 2, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 2, imagen 3 de 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Front Cover, Back Cover: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
  4. Disassembling Kodak Easyshare C813 Front Cover: paso 4, imagen 1 de 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Front Cover: paso 5, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 5, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 5, imagen 3 de 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Front Cover: paso 6, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 6, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 6, imagen 3 de 3
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Front Cover: paso 7, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 7, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 7, imagen 3 de 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Front Cover: paso 8, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 8, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 8, imagen 3 de 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Disassembling Kodak Easyshare C813 Front Cover, Front Cover: paso 9, imagen 1 de 2 Disassembling Kodak Easyshare C813 Front Cover, Front Cover: paso 9, imagen 2 de 2
    • Open the battery door.
  10. Disassembling Kodak Easyshare C813 Front Cover: paso 10, imagen 1 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 10, imagen 2 de 3 Disassembling Kodak Easyshare C813 Front Cover: paso 10, imagen 3 de 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Disassembling Kodak Easyshare C813 Front Cover: paso 11, imagen 1 de 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
Linea de Meta
2 personas más completaron esta guía.
Susan Marano
Miembro Desde 04/15/10
336 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 24-22, Regan Spring 2010 Miembro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,887
