Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Kodak Easyshare C813 Back Cover
Qué necesitas
  1. Disassembling Kodak Easyshare C813 Back Cover, Battery: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Back Cover: paso 2, imagen 1 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 2, imagen 2 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 2, imagen 3 de 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
  4. Disassembling Kodak Easyshare C813 Back Cover: paso 4, imagen 1 de 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Back Cover: paso 5, imagen 1 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 5, imagen 2 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 5, imagen 3 de 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Back Cover: paso 6, imagen 1 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 6, imagen 2 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 6, imagen 3 de 3
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Back Cover: paso 7, imagen 1 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 7, imagen 2 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 7, imagen 3 de 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Back Cover: paso 8, imagen 1 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 8, imagen 2 de 3 Disassembling Kodak Easyshare C813 Back Cover: paso 8, imagen 3 de 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-22, Regan Spring 2010 Miembro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
Miembros de 4
22 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 32
Ultimos 30 días: 91
Todo El Tiempo: 2,858
