Saltar al contenido principal
Disassembling Kodak Advantix F350 Back Cover
Qué necesitas
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: paso 1, imagen 1 de 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: paso 2, imagen 1 de 2 Disassembling Kodak Advantix F350 Back Cover: paso 2, imagen 2 de 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: paso 3, imagen 1 de 3 Disassembling Kodak Advantix F350 Back Cover: paso 3, imagen 2 de 3 Disassembling Kodak Advantix F350 Back Cover: paso 3, imagen 3 de 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: paso 4, imagen 1 de 2 Disassembling Kodak Advantix F350 Back Cover: paso 4, imagen 2 de 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: paso 5, imagen 1 de 2 Disassembling Kodak Advantix F350 Back Cover: paso 5, imagen 2 de 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: paso 6, imagen 1 de 3 Disassembling Kodak Advantix F350 Back Cover: paso 6, imagen 2 de 3 Disassembling Kodak Advantix F350 Back Cover: paso 6, imagen 3 de 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Conclusión
Equipo
UW Stout, Team 1-2, Zhou Fall 2011 Miembro de UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 19
Todo El Tiempo: 1,090
