Saltar al contenido principal
Disassembling KDDI Kyocera A5521K Faceplate
Qué necesitas
  1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 3 de 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Faceplate: paso 2, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 2, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 2, imagen 3 de 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: paso 3, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: paso 3, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: paso 3, imagen 3 de 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Disassembling KDDI Kyocera A5521K Faceplate: paso 4, imagen 1 de 1
    • Remove the screws using a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Faceplate: paso 5, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 5, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 5, imagen 3 de 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Disassembling KDDI Kyocera A5521K Faceplate: paso 6, imagen 1 de 1
    • Use the Y0 screwdriver to remove the screws.
  7. Disassembling KDDI Kyocera A5521K Faceplate: paso 7, imagen 1 de 2 Disassembling KDDI Kyocera A5521K Faceplate: paso 7, imagen 2 de 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Disassembling KDDI Kyocera A5521K Faceplate: paso 8, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 8, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Faceplate: paso 8, imagen 3 de 3
    • Separate the faceplate from the phone.
Conclusión
Una persona más ha completado esta guía.
Dominic Grisafe
Miembro Desde 04/15/10
157 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 28-25, Regan Spring 2010 Miembro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,697
