Saltar al contenido principal
Disassembling JVC GR-D290U
Qué necesitas
  1. Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: paso 1, imagen 1 de 2 Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: paso 1, imagen 2 de 2
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
  2. Disassembling JVC GR-D290U: paso 2, imagen 1 de 3 Disassembling JVC GR-D290U: paso 2, imagen 2 de 3 Disassembling JVC GR-D290U: paso 2, imagen 3 de 3
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
  3. Disassembling JVC GR-D290U: paso 3, imagen 1 de 1
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
  4. Disassembling JVC GR-D290U: paso 4, imagen 1 de 1
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
  5. Disassembling JVC GR-D290U: paso 5, imagen 1 de 2 Disassembling JVC GR-D290U: paso 5, imagen 2 de 2
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
Conclusión
2 personas más completaron esta guía.
justin chen
Miembro Desde 04/27/10
47 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-69, Johann Spring 2010 Miembro de Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 3,945
