Saltar al contenido principal
Disassembling Insignia NS-B2110 Internal Components
Qué necesitas
  1. Disassembling Insignia NS-B2110 Internal Components, Battery: paso 1, imagen 1 de 2 Disassembling Insignia NS-B2110 Internal Components, Battery: paso 1, imagen 2 de 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Disassembling Insignia NS-B2110 Internal Components: paso 2, imagen 1 de 2 Disassembling Insignia NS-B2110 Internal Components: paso 2, imagen 2 de 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Disassembling Insignia NS-B2110 Internal Components, Bottom Panel: paso 3, imagen 1 de 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Disassembling Insignia NS-B2110 Internal Components: paso 4, imagen 1 de 2 Disassembling Insignia NS-B2110 Internal Components: paso 4, imagen 2 de 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Disassembling Insignia NS-B2110 Internal Components: paso 5, imagen 1 de 3 Disassembling Insignia NS-B2110 Internal Components: paso 5, imagen 2 de 3 Disassembling Insignia NS-B2110 Internal Components: paso 5, imagen 3 de 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Disassembling Insignia NS-B2110 Internal Components, Internal Components: paso 6, imagen 1 de 2 Disassembling Insignia NS-B2110 Internal Components, Internal Components: paso 6, imagen 2 de 2
    • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
    • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
    • Remove the green quarter circle circuit board and place to the side.
  7. Disassembling Insignia NS-B2110 Internal Components: paso 7, imagen 1 de 1
    • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
  8. Disassembling Insignia NS-B2110 Internal Components: paso 8, imagen 1 de 1
    • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
  9. Disassembling Insignia NS-B2110 Internal Components: paso 9, imagen 1 de 1
    • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
  10. Disassembling Insignia NS-B2110 Internal Components: paso 10, imagen 1 de 1
    • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
    • Remove the rectangular circuit board and place it to the side.
  11. Disassembling Insignia NS-B2110 Internal Components: paso 11, imagen 1 de 1
    • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
    • Remove the black plastic frame.
  12. Disassembling Insignia NS-B2110 Internal Components: paso 12, imagen 1 de 2 Disassembling Insignia NS-B2110 Internal Components: paso 12, imagen 2 de 2
    • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
    • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
    • Remove and place the metal circuit board to the side.
  13. Disassembling Insignia NS-B2110 Internal Components: paso 13, imagen 1 de 1
    • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
Conclusión
Una persona más ha completado esta guía.
Daniel Hodges
Miembro Desde 10/14/13
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-31, Amido Fall 2013 Miembro de Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 899
