Saltar al contenido principal
Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
Qué necesitas
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: paso 1, imagen 1 de 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: paso 1, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: paso 2, imagen 1 de 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: paso 2, imagen 2 de 2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: paso 3, imagen 1 de 1
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: paso 4, imagen 1 de 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: paso 4, imagen 2 de 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: paso 4, imagen 3 de 3
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Conclusión
Alan
Miembro Desde 10/07/10
380 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
Miembros de 4
26 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,028
