Saltar al contenido principal
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: paso 1, imagen 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: paso 1, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: paso 2, imagen 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: paso 2, imagen 2 de 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: paso 3, imagen 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: paso 3, imagen 2 de 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
Conclusión
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
Miembro Desde 10/06/10
162 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 2,676
