Saltar al contenido principal
Disassembling IBM ThinkPad A30 CPU
Qué necesitas
  1. Disassembling IBM ThinkPad A30 CPU, Battery: paso 1, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU, Battery: paso 1, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 CPU, Hard Drive: paso 2, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU, Hard Drive: paso 2, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU, Hard Drive: paso 2, imagen 3 de 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 CPU, Upper Case: paso 3, imagen 1 de 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 CPU: paso 4, imagen 1 de 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 CPU: paso 5, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU: paso 5, imagen 2 de 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 CPU: paso 6, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 6, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 6, imagen 3 de 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 CPU: paso 7, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 7, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 7, imagen 3 de 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 CPU: paso 8, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU: paso 8, imagen 2 de 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 CPU: paso 9, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 9, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 9, imagen 3 de 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  10. Disassembling IBM ThinkPad A30 CPU, Display Assembly: paso 10, imagen 1 de 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  11. Disassembling IBM ThinkPad A30 CPU: paso 11, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 11, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 11, imagen 3 de 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  12. Disassembling IBM ThinkPad A30 CPU: paso 12, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU: paso 12, imagen 2 de 2
    • Pull out the white tab connecting the LCD to the motherboard.
  13. Disassembling IBM ThinkPad A30 CPU: paso 13, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU: paso 13, imagen 2 de 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  14. Disassembling IBM ThinkPad A30 CPU: paso 14, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 14, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 14, imagen 3 de 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  15. Disassembling IBM ThinkPad A30 CPU, Fan: paso 15, imagen 1 de 1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
  16. Disassembling IBM ThinkPad A30 CPU: paso 16, imagen 1 de 1
    • Lift the heatsink bracket up.
  17. Disassembling IBM ThinkPad A30 CPU: paso 17, imagen 1 de 3 Disassembling IBM ThinkPad A30 CPU: paso 17, imagen 2 de 3 Disassembling IBM ThinkPad A30 CPU: paso 17, imagen 3 de 3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
  18. Disassembling IBM ThinkPad A30 CPU, CPU: paso 18, imagen 1 de 2 Disassembling IBM ThinkPad A30 CPU, CPU: paso 18, imagen 2 de 2
    • Use a flathead to turn the screw 180 degrees.
    • Remove the CPU by lifting it upwards.
    • If the CPU is reusable, place it in an antistatic bag and away from moisture.
Conclusión
Jessica
Miembro Desde 10/06/10
162 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,813
