Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling HTC One V Back Case
Qué necesitas
  1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: paso 1, imagen 1 de 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: paso 1, imagen 2 de 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: paso 1, imagen 3 de 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
    Pregunta a FixBot
    Agregar Comentario
  2. Disassembling HTC One V Back Case: paso 2, imagen 1 de 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
    Pregunta a FixBot
    Agregar Comentario
  3. Disassembling HTC One V Back Case: paso 3, imagen 1 de 2 Disassembling HTC One V Back Case: paso 3, imagen 2 de 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    Pregunta a FixBot
    Agregar Comentario
  4. Disassembling HTC One V Back Case: paso 4, imagen 1 de 3 Disassembling HTC One V Back Case: paso 4, imagen 2 de 3 Disassembling HTC One V Back Case: paso 4, imagen 3 de 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
    Pregunta a FixBot
    Agregar Comentario
  5. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: paso 5, imagen 1 de 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: paso 5, imagen 2 de 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: paso 5, imagen 3 de 3
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
    Pregunta a FixBot
    Agregar Comentario
  6. Disassembling HTC One V Back Case: paso 6, imagen 1 de 3 Disassembling HTC One V Back Case: paso 6, imagen 2 de 3 Disassembling HTC One V Back Case: paso 6, imagen 3 de 3
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
    Pregunta a FixBot
    Agregar Comentario
  7. Disassembling HTC One V Back Case: paso 7, imagen 1 de 3 Disassembling HTC One V Back Case: paso 7, imagen 2 de 3 Disassembling HTC One V Back Case: paso 7, imagen 3 de 3
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-3, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
Miembros de 4
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 40
Todo El Tiempo: 3,515
