Saltar al contenido principal
Disassembling HP Photosmart D110a Printer Hood
Qué necesitas
  1. Disassembling HP Photosmart D110a Printer Hood, Printer Hood Assembly: paso 1, imagen 1 de 1
    • First, begin by removing the printer's hood.
    • Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. Disassembling HP Photosmart D110a Printer Hood: paso 2, imagen 1 de 1
    • Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
  3. Disassembling HP Photosmart D110a Printer Hood: paso 3, imagen 1 de 1
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
  4. Disassembling HP Photosmart D110a Printer Hood: paso 4, imagen 1 de 3 Disassembling HP Photosmart D110a Printer Hood: paso 4, imagen 2 de 3 Disassembling HP Photosmart D110a Printer Hood: paso 4, imagen 3 de 3
    • Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
  5. Disassembling HP Photosmart D110a Printer Hood: paso 5, imagen 1 de 2 Disassembling HP Photosmart D110a Printer Hood: paso 5, imagen 2 de 2
    • To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
    • Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the power button panel by pulling from right to left.
  6. Disassembling HP Photosmart D110a Printer Hood: paso 6, imagen 1 de 2 Disassembling HP Photosmart D110a Printer Hood: paso 6, imagen 2 de 2
    • Remove the exposed screw that was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. Disassembling HP Photosmart D110a Printer Hood: paso 7, imagen 1 de 3 Disassembling HP Photosmart D110a Printer Hood: paso 7, imagen 2 de 3 Disassembling HP Photosmart D110a Printer Hood: paso 7, imagen 3 de 3
    • This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
    • Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
    • When all three cables are removed, lift the hood away from the printer and set it aside.
  8. Disassembling HP Photosmart D110a Printer Hood, Disassembling HP Photosmart D110a Printer Hood: paso 8, imagen 1 de 3 Disassembling HP Photosmart D110a Printer Hood, Disassembling HP Photosmart D110a Printer Hood: paso 8, imagen 2 de 3 Disassembling HP Photosmart D110a Printer Hood, Disassembling HP Photosmart D110a Printer Hood: paso 8, imagen 3 de 3
    • After being separated from the printer, the hood is ready to be disassembled.
    • Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
  9. Disassembling HP Photosmart D110a Printer Hood: paso 9, imagen 1 de 2 Disassembling HP Photosmart D110a Printer Hood: paso 9, imagen 2 de 2
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
  10. Disassembling HP Photosmart D110a Printer Hood: paso 10, imagen 1 de 2 Disassembling HP Photosmart D110a Printer Hood: paso 10, imagen 2 de 2
    • Carefully separate the two hood pieces connected by the black ribbon.
    • Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
    • The printer hood should now be in 2 pieces.
Conclusión
19 personas más completaron esta guía.
Equipo
Cal Poly, Team 10-38, Forte Spring 2011 Miembro de Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Miembros
10 Guías creadas
9 comentarios
Thanks for this guide. I never would have found that fourth screw without this guide. The illustration of the "clip" for removal of the power quadrant face could have been more detailed and/or you could have said in the description, "Feel for the TAB on the right center of the power button quadrant behind the "cartridge door open" feeler and push it toward the outside of the printer". Other than that, this was great.
Just A Mechanic - Contestar
Hi Joseph,
Thanks for the guide. Very easy to follow. Saved me some dollars.
joenovelo - Contestar
Great Support,.!!!
I am a handy person and a Computer tech for family and friends,.
Some time You just need Instruction on how to do do things, Other wise You taking the risks of braking things instead of fixing them
Thanks Guys
Milton Portillo - Contestar
Thank you for posting this. In place of the pliers, I recommend using a small reversible ratchet offset (mine was 3-1/4"W x 6-3/4"L x 1/2"H) to remove the 4th screw. It won't slide of the screw like pliers and will make both the removal and replacement much easier.
theratchet - Contestar
Where can I find spare parts for HP PSC photosmart D110?
Regards
Carlos Ahumada - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 20,932
