Saltar al contenido principal
Introducción
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
Partes
No se especificaron partes.
  1. Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up), Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 1, imagen 1 de 1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 2, imagen 1 de 3 Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 2, imagen 2 de 3 Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 2, imagen 3 de 3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
Conclusión
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,088
