Introducción
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
Partes
No se requieren partes.
Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
Agregar Comentario
Slide the blue opening tool along the seam applying force to continue detaching the side panel.
  • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
  • Remove the button from the side panel.
Agregar Comentario
Conclusión
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,011
