Saltar al contenido principal
Introducción
The Griffin iFM 4027 LCD screen cover is necessary for protecting the device’s LCD screen. The screen cover can be removed using the steps in this guide.
Partes
No se especificaron partes.
    • First, lodge the tip of the plastic iFixit opening tool into the top corner of the device.
    • Apply pressure upward with the iFixit Opening Tool. This should release the two panels away from each other.
  1. Disassembling Griffin iFM 4027 LCD Screen Cover: paso 2, imagen 1 de 3 Disassembling Griffin iFM 4027 LCD Screen Cover: paso 2, imagen 2 de 3 Disassembling Griffin iFM 4027 LCD Screen Cover: paso 2, imagen 3 de 3
    • Use your fingers to separate the right side panel from the device.
    • Turn the panel over so that the outer edge is facing downward.
    • Use your fingers to dislodge the buttons, and then set them aside for later.
  2. Disassembling Griffin iFM 4027 LCD Screen Cover, Disassembling Griffin iFM 4027 Left Side Panel (Screen Side Up): paso 3, imagen 1 de 1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  3. Disassembling Griffin iFM 4027 LCD Screen Cover: paso 4, imagen 1 de 3 Disassembling Griffin iFM 4027 LCD Screen Cover: paso 4, imagen 2 de 3 Disassembling Griffin iFM 4027 LCD Screen Cover: paso 4, imagen 3 de 3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
  4. Disassembling Griffin iFM 4027 LCD Screen Cover, Disassembling Griffin iFM 4027 Central Button: paso 5, imagen 1 de 2 Disassembling Griffin iFM 4027 LCD Screen Cover, Disassembling Griffin iFM 4027 Central Button: paso 5, imagen 2 de 2
    • Use your fingers to push down on the center button and move it to the left, sliding it out from under the front panel.
    • Once removed, set the center button aside.
  5. Disassembling Griffin iFM 4027 LCD Screen Cover, Disassembling Griffin iFM 4027 LCD Screen Cover: paso 6, imagen 1 de 2 Disassembling Griffin iFM 4027 LCD Screen Cover, Disassembling Griffin iFM 4027 LCD Screen Cover: paso 6, imagen 2 de 2
    • Carefully remove the circuit board and attached LCD component from the device by pulling it towards the open left side.
  6. Disassembling Griffin iFM 4027 LCD Screen Cover: paso 7, imagen 1 de 1
    • Carefully lift the rectangular screen cover off the LCD screen.
Conclusión
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
Miembro Desde 09/03/12
101 Reputación
9 Guías creadas
Equipo
Clemson, Team 15-3, Benson Spring 2012 Miembro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 860
