Introducción
This guide gives step-by-step instructions for removing the outer shell of the base to assess the logic board within the phone. After completing this guide, you will have access to the logic board and all other interior parts of the telephone.
Qué necesitas
Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
Slide the door off of the battery compartment.
Remove the battery from the phone.
Locate the volume dial on the right side of the telephone.
Remove the volume dial by gently grasping it and pulling it away from the base.
Remove the three 12 mm screws with a Phillips #1 screwdriver.
Remove the three 18 mm screws with a Phillips #1 screwdriver.
Pry off the base shell using a plastic opener tool.
Set the shell aside.
Reassemble your devise by following these instructions in reverse order.
