Saltar al contenido principal
Disassembling General Electric Telephone 2-9710A Base Shell
Qué necesitas
  1. Disassembling General Electric Telephone 2-9710A Base Shell, Phone Cord: paso 1, imagen 1 de 2 Disassembling General Electric Telephone 2-9710A Base Shell, Phone Cord: paso 1, imagen 2 de 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Base Shell: paso 2, imagen 1 de 3 Disassembling General Electric Telephone 2-9710A Base Shell: paso 2, imagen 2 de 3 Disassembling General Electric Telephone 2-9710A Base Shell: paso 2, imagen 3 de 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Base Shell, 9V Base Battery: paso 3, imagen 1 de 2 Disassembling General Electric Telephone 2-9710A Base Shell, 9V Base Battery: paso 3, imagen 2 de 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Disassembling General Electric Telephone 2-9710A Base Shell, Remove Volume Dial: paso 4, imagen 1 de 2 Disassembling General Electric Telephone 2-9710A Base Shell, Remove Volume Dial: paso 4, imagen 2 de 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Disassembling General Electric Telephone 2-9710A Base Shell, Remove Screws on the Back: paso 5, imagen 1 de 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Disassembling General Electric Telephone 2-9710A Base Shell, Pry the Back Off: paso 6, imagen 1 de 2 Disassembling General Electric Telephone 2-9710A Base Shell, Pry the Back Off: paso 6, imagen 2 de 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
Conclusión
Reassemble your devise by following these instructions in reverse order.
Alles Rebel
Miembro Desde 09/20/12
72 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 789
