Saltar al contenido principal
Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
Qué necesitas
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: paso 1, imagen 1 de 1
    • Unplug the toaster from the electrical outlet.
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: paso 2, imagen 1 de 2 Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: paso 2, imagen 2 de 2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: paso 3, imagen 1 de 1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
Conclusión
Ron Gajdos
Miembro Desde 10/16/13
307 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,088
