Saltar al contenido principal
Disassembling Galaxy Tab S 10.5 Back Rim Cover
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Disassembling Galaxy Tab S 10.5 Back Rim Cover, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 1 de 2 Disassembling Galaxy Tab S 10.5 Back Rim Cover, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 2 de 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Disassembling Galaxy Tab S 10.5 Back Rim Cover: paso 2, imagen 1 de 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Disassembling Galaxy Tab S 10.5 Back Rim Cover: paso 3, imagen 1 de 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Disassembling Galaxy Tab S 10.5 Back Rim Cover, Back Rim Cover: paso 4, imagen 1 de 3 Disassembling Galaxy Tab S 10.5 Back Rim Cover, Back Rim Cover: paso 4, imagen 2 de 3 Disassembling Galaxy Tab S 10.5 Back Rim Cover, Back Rim Cover: paso 4, imagen 3 de 3
    • Place the plastic opening tool in between the outer rim.
    • Move the tool in a downward motion to separate the 2 parts.
    • Run the tool along the rim to disconnect all connectors holding the outer rim to the back of the device.
  5. Disassembling Galaxy Tab S 10.5 Back Rim Cover: paso 5, imagen 1 de 1
    • Repeat this step for all four sides, then remove the rim.
Conclusión
Una persona más ha completado esta guía.
Jordan Soto
Miembro Desde 08/26/15
3,249 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-2, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 159
