Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will be helpful if you need to replace any part of the camera that does not have a specific repair guide. To complete this guide, you will need to desolder wires from the motherboard and circuit boards. Learn more about soldering here.
  1. Turn the camera upside down. Place your thumb on the switch, and slide it towards the center of the camera.
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Pull the battery out.
    • Pull the battery out.
  4. Begin by removing the outside screws using a Phillips #000 Screwdriver: Remove the three 3.6 mm silver screws located on the bottom of the camera. Remove all  four of the 4.7 mm screws from the sides of the camera.
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Remove all screws below using a Phillips #000 Screwdriver: Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove all screws below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Carefully lift up the bottom piece of the camera to remove it.
    • Carefully lift up the bottom piece of the camera to remove it.
  7. Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. For all five indicated  orange strips: Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it. Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. For the last orange strip located behind the top strip:
    • For the last orange strip located behind the top strip:
  10. This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
    • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
    • For the two orange strips attached to the capacitor circuitboard:
  11. Remove all screws listed below using a Phillips #000 screwdriver: Remove the two 3.4 mm screws at the bottom of the silver plate. Hold back the clear strip to reveal a  2.8 mm screw on the left of the silver plate and remove it.
    • Remove all screws listed below using a Phillips #000 screwdriver:
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  12. Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
  13. Tilt up the motherboard to locate the black, grey, and red wires. Desolder these wires in order to completely remove the motherboard.
    • Tilt up the motherboard to locate the black, grey, and red wires.
    • Desolder these wires in order to completely remove the motherboard.
    • You can learn about soldering techniques here.
  14. Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
    • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
  15. Pull the lens toward the bottom of the camera so it can clear the silver tab. Then push the lens with your index fingers from the front of the camera until it is removed.
    • Pull the lens toward the bottom of the camera so it can clear the silver tab.
    • Then push the lens with your index fingers from the front of the camera until it is removed.
  16. Do not touch the leads on the capacitor below the green circuitboard because they can shock you. Remove the silver 3.4 mm screw from the top left corner of the capacitor circuitboard using a Phillips #000 screwdriver.
    • Do not touch the leads on the capacitor below the green circuitboard because they can shock you.
    • Remove the silver 3.4 mm screw from the top left corner of the capacitor circuitboard using a Phillips #000 screwdriver.
    • Desolder the red, black, grey, and green wires attached to the capacitor circuitboard so the circuitboard is disconnected and can be set aside.
  17. Rotate the camera so you are looking at the bottom. Remove the two silver 3.4 mm screws on the silver plate that are holding the eyepiece using a Phillips #000 screwdriver.
    • Rotate the camera so you are looking at the bottom.
    • Remove the two silver 3.4 mm screws on the silver plate that are holding the eyepiece using a Phillips #000 screwdriver.
    • Lift the eyepiece out of the camera.
  18. To remove the LCD screen, look at the back of the tiltable screen plate. Remove the two black 3.7 mm screws in the back corners of the screen plate using a Phillips #000 screwdriver.
    • To remove the LCD screen, look at the back of the tiltable screen plate.
    • Remove the two black 3.7 mm screws in the back corners of the screen plate using a Phillips #000 screwdriver.
    • Lay the back panel flat to lift off the clear casing that is over the LCD screen.
  19. You have disassembled the Fujifilm X30 camera!
    • You have disassembled the Fujifilm X30 camera!
Conclusión
8 personas más completaron esta guía.
Jay Sterner
Miembro Desde 12/01/16
433 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 70-3, Forte Winter 2016 Miembro de Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 Miembros
4 Guías creadas
the big question is how to repair the common stuck open flash?
Don Makaveli - Contestar
and the broken battery latch (orange tab)? Thanks.
yoyoy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 79
Todo El Tiempo: 9,066
