Introducción
Removing the outer case of the camera.
Partes
No se requieren partes.
  1. Remove the batteries from the camera to prevent danger of electric shock.
    • Remove the batteries from the camera to prevent danger of electric shock.
  2. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws.
    • Locate all five screws on the camera. Then proceed to remove all the screws.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • If your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws.
  5. Remove outer case.  Pull the back away from the main body of the camera. Remove outer case.  Pull the back away from the main body of the camera.
    • Remove outer case. Pull the back away from the main body of the camera.
Conclusión
Cody
Miembro Desde 18/04/10
47 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-11, Maness Spring 2010 Miembro de Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 3,407
