Saltar al contenido principal
Disassembling Eureka 1660SP Motor Housing
Qué necesitas
  1. Disassembling Eureka 1660SP Motor Housing, Motor Housing: paso 1, imagen 1 de 2 Disassembling Eureka 1660SP Motor Housing, Motor Housing: paso 1, imagen 2 de 2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Disassembling Eureka 1660SP Motor Housing: paso 2, imagen 1 de 2 Disassembling Eureka 1660SP Motor Housing: paso 2, imagen 2 de 2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Disassembling Eureka 1660SP Motor Housing: paso 3, imagen 1 de 3 Disassembling Eureka 1660SP Motor Housing: paso 3, imagen 2 de 3 Disassembling Eureka 1660SP Motor Housing: paso 3, imagen 3 de 3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 351
