Saltar al contenido principal
Disassembling Ericsson CF 388 Sim Card
Qué necesitas
  1. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: paso 1, imagen 1 de 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: paso 1, imagen 2 de 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: paso 1, imagen 3 de 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: paso 2, imagen 1 de 2 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: paso 2, imagen 2 de 2
    • After removing the battery, the SIM card is accessible. Locate the SIM card casing at the bottom right of the back of the front panel casing.
    • To remove the SIM card, using your index finger, carefully lift up and rotate the plastic casing.
    • Then, the SIM card easily slides out of the casing.
Conclusión
Cam Miller
Miembro Desde 03/09/12
1 Reputación
1 Guía escrita
Equipo
Clemson, Team 1-1, Benson Spring 2012 Miembro de Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 975
