Saltar al contenido principal
Disassembling Ericsson CF 388 Phone Casing
Qué necesitas
  1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: paso 1, imagen 1 de 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: paso 1, imagen 2 de 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: paso 1, imagen 3 de 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: paso 2, imagen 1 de 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: paso 2, imagen 2 de 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: paso 2, imagen 3 de 3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Phone Casing: paso 3, imagen 1 de 3 Disassembling Ericsson CF 388 Phone Casing: paso 3, imagen 2 de 3 Disassembling Ericsson CF 388 Phone Casing: paso 3, imagen 3 de 3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Phone Casing: paso 4, imagen 1 de 2 Disassembling Ericsson CF 388 Phone Casing: paso 4, imagen 2 de 2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
Conclusión
2 personas más completaron esta guía.
Niccolas Tones
Miembro Desde 03/09/12
60 Reputación
9 Guías creadas
Equipo
Clemson, Team 1-1, Benson Spring 2012 Miembro de Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,147
