Saltar al contenido principal
Disassembling Equity Alarm Clock 13014 Alarm Component
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Battery: paso 1, imagen 1 de 3 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Battery: paso 1, imagen 2 de 3 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Battery: paso 1, imagen 3 de 3
    • Remove battery cover using the 26 bit driver kit with the #030 bit screwdriver or use thumbnail into indentation within the battery cover. Proceed with the removal of the battery. Set battery and battery cover aside.
  2. Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Back Cover: paso 2, imagen 1 de 3 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Back Cover: paso 2, imagen 2 de 3 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Back Cover: paso 2, imagen 3 de 3
    • Using the 26 bit driver kit, use the PH1 screwdriver bit to remove the three gold screws from the black plastic back plate from the alarm clock.
  3. Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Plastic Back Plate: paso 3, imagen 1 de 2 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Plastic Back Plate: paso 3, imagen 2 de 2
    • Carefully lift the black plastic back plate away from the alarm main component.
  4. Disassembling Equity Alarm Clock 13014 Alarm Component, Locating and Removing the Solenoid Brace: paso 4, imagen 1 de 2 Disassembling Equity Alarm Clock 13014 Alarm Component, Locating and Removing the Solenoid Brace: paso 4, imagen 2 de 2
    • The solenoid is located in the upper right corner of the alarm clock and is supported by a silver brace. Using the screwdriver remove the silver screw from the silver brace supporting the solenoid. Set the silver brace aside.
  5. Disassembling Equity Alarm Clock 13014 Alarm Component, Getting to the Alarm Solenoid: paso 5, imagen 1 de 2 Disassembling Equity Alarm Clock 13014 Alarm Component, Getting to the Alarm Solenoid: paso 5, imagen 2 de 2
    • Carefully remove the silver brace which is located on top of the cylindrical solenoid. Set aside.
  6. Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Alarm Bell Striker: paso 6, imagen 1 de 2 Disassembling Equity Alarm Clock 13014 Alarm Component, Removing the Alarm Bell Striker: paso 6, imagen 2 de 2
    • Using the mini screwdriver remove the silver screw located within the white plastic post located on the right side of the solenoid and remove the striker from the bottom of the oval opening which is located on the top of the alarm clock.
    • After removing the screw from the alarm plastic post, remove the ringer by feeding the ringer through the bottom of the top oval opening located at the top of the alarm clock.
    • Remove the right hand silver screw from the central square plastic apparatus. Set aside. Repeat with the left hand silver screw. Set aside.
    • Remove the left leg and washer by unscrewing counterclockwise by hand. Set aside. Repeat with the right leg and washer.
    • Using needle nose pliers, remove the left alarm bell post top. Set aside. Repeat with the right alarm bell post. Set aside. Remove the top handle from the pair of bells. Set aside.
    • Remove the right post with needle nose pliers by unscrewing counterclockwise. Set aside. Repeat with left post. Set aside.
    • Remove by hand, the black plastic central component. Invert to remove hex screws. Set aside.
  7. Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers, pull upward to remove the central post out from the clock hands. Remove the second hand and set aside. Repeat the process with the hour and minute hands. Set aside.
Conclusión
Una persona más ha completado esta guía.
Un comentario
hello i just wanted to ask if you could add the pictures to the steps because i’m doing a project in reverse engineering and this article helps alot but it would help more if you could add the pictures. please?
Juan Barajas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 459
