Saltar al contenido principal
Disassembling Dell Inspiron One 2020 Back Cover
Qué necesitas
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: paso 1, imagen 1 de 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: paso 1, imagen 2 de 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: paso 1, imagen 3 de 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: paso 2, imagen 1 de 3 Disassembling Dell Inspiron One 2020 Back Cover: paso 2, imagen 2 de 3 Disassembling Dell Inspiron One 2020 Back Cover: paso 2, imagen 3 de 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: paso 3, imagen 1 de 3 Disassembling Dell Inspiron One 2020 Back Cover: paso 3, imagen 2 de 3 Disassembling Dell Inspiron One 2020 Back Cover: paso 3, imagen 3 de 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Conclusión
28 personas más completaron esta guía.
Tyler
Miembro Desde 06/19/12
4,920 Reputación
16 Guías creadas
Equipo
TechForce Miembro de TechForce
Business
2 Miembros
25 Guías creadas
Un comentario
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 48
Todo El Tiempo: 33,837
