Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
We'll remove the top cover from the device, allowing the other components to be seen and replaced or repaired.
Partes
No se especificaron partes.
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin. Flip your device over so the bottom panel is facing up.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard. Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  4. Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking. Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
Conclusión
2 personas más completaron esta guía.
Amrit Multani
Miembro Desde 14/07/15
115 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-1, Liner SU 2015 Miembro de UW Tacoma, Team 1-1, Liner SU 2015
UWT-LINER-SU15S1G1
3 Miembros
4 Guías creadas
Can I get a broken screen
Daniel Mwangi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 590
