Saltar al contenido principal
Disassembling Coby Kyros MID9742 Outer Casing
Qué necesitas
  1. Disassembling Coby Kyros MID9742 Outer Casing, Outer Casing: paso 1, imagen 1 de 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Disassembling Coby Kyros MID9742 Outer Casing: paso 2, imagen 1 de 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Disassembling Coby Kyros MID9742 Outer Casing: paso 3, imagen 1 de 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
Conclusión
Una persona más ha completado esta guía.
Ian Swett
Miembro Desde 03/11/15
597 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 467
