Saltar al contenido principal
Disassembling Circo Monkey Alarm Clock Clock Face
Qué necesitas
  1. Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: paso 1, imagen 1 de 3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: paso 1, imagen 2 de 3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: paso 1, imagen 3 de 3
    • Grasp the plastic cover and carefully pull straight back so that the clock cover dislodges from its housing.
    • If any additional assistance is required for this step, it is recommended to use the plastic opening tool to help pry the edges of the cover simultaneously or a suction cup if you cannot grip the rim.
  2. Disassembling Circo Monkey Alarm Clock Clock Face: paso 2, imagen 1 de 1
    • Using your fingers, grasp the point where the hands of the clock meet in the center and pull straight back until they dislodge from the motor.
    • Be sure that you remove all three hands as well as the pin that connects them in this one step. This component should come out as a single piece.
Conclusión
Una persona más ha completado esta guía.
Devin Gooding
Miembro Desde 01/20/15
110 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 19-1, Blackwell Winter 2015 Miembro de USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 517
