Saltar al contenido principal
Disassembling Casio Exilim EX-Z850 Outer Casing
Qué necesitas
  1. Disassembling Casio Exilim EX-Z850 Outer Casing, Disassembling Casio Exilim EX-Z850 Outer Casing: paso 1, imagen 1 de 3 Disassembling Casio Exilim EX-Z850 Outer Casing, Disassembling Casio Exilim EX-Z850 Outer Casing: paso 1, imagen 2 de 3 Disassembling Casio Exilim EX-Z850 Outer Casing, Disassembling Casio Exilim EX-Z850 Outer Casing: paso 1, imagen 3 de 3
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Disassembling Casio Exilim EX-Z850 Outer Casing: paso 2, imagen 1 de 3 Disassembling Casio Exilim EX-Z850 Outer Casing: paso 2, imagen 2 de 3 Disassembling Casio Exilim EX-Z850 Outer Casing: paso 2, imagen 3 de 3
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Disassembling Casio Exilim EX-Z850 Outer Casing: paso 3, imagen 1 de 2 Disassembling Casio Exilim EX-Z850 Outer Casing: paso 3, imagen 2 de 2
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
Conclusión
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 personas más completaron esta guía.
Logan
Miembro Desde 01/10/11
313 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 27
Ultimos 30 días: 35
Todo El Tiempo: 2,981
