Saltar al contenido principal
Introducción
The LCD display can be removed and replaced if it is cracked or broken.
Partes
No se especificaron partes.
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen. Disconnect the ribbons connecting the screen to the camera. Lift off the screen.
    • Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen.
    • Disconnect the ribbons connecting the screen to the camera.
    • Lift off the screen.
Conclusión
Ben Tupas
Miembro Desde 13/01/11
317 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,160
