Saltar al contenido principal
Disassembling Canon PowerShot SD800 IS Front Cover
Qué necesitas
  1. Disassembling Canon PowerShot SD800 IS Front Cover, Back Cover: paso 1, imagen 1 de 1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Front Cover: paso 2, imagen 1 de 1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Front Cover: paso 3, imagen 1 de 1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Front Cover: paso 4, imagen 1 de 1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS Front Cover, Front Cover: paso 5, imagen 1 de 1
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Disassembling Canon PowerShot SD800 IS Front Cover: paso 6, imagen 1 de 1
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Disassembling Canon PowerShot SD800 IS Front Cover: paso 7, imagen 1 de 1
    • Pull off the front cover.
Conclusión
Jeremy Rabaino
Miembro Desde 10/10/10
135 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-9, Maness Fall 2010 Miembro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 2,488
