Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Canon PowerShot SD1100 IS LCD screen
Qué necesitas
  1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: paso 1, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: paso 1, imagen 2 de 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 2, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 2, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 2, imagen 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 3, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 3, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 3, imagen 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 4, imagen 1 de 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: paso 5, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: paso 5, imagen 2 de 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 6, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 6, imagen 2 de 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 7, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 7, imagen 2 de 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 9, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 9, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: paso 9, imagen 3 de 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS LCD screen: paso 10, imagen 1 de 1
    • The LCD screen should now be removed.
Conclusión
3 personas más completaron esta guía.
Tyler Grossheim
Miembro Desde 01/25/11
1,623 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 67
Todo El Tiempo: 4,072
