Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Canon PowerShot SD1100 IS Camera Lens
Qué necesitas
    1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: paso 1, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: paso 1, imagen 2 de 2
      • Remove wrist strap and battery.
      Pregunta a FixBot
      Agregar Comentario
    2. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 3 de 3
      • Remove 2 screws from each side of the camera (4 total, 0.102 in).
      • Remove 2 screws from the bottom on the camera (0.138 in).
      • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
      Pregunta a FixBot
      Agregar Comentario
    3. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 3 de 3
      • Gently pull off the front cover.
      • The plate on the side should come off.
      • Gently pull off the back cover.
      Pregunta a FixBot
      Agregar Comentario
    4. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 4, imagen 1 de 1
      • The cases should now be removed.
      Pregunta a FixBot
      Agregar Comentario
    1. Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: paso 5, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: paso 5, imagen 2 de 2
      • Remove the top-left screw above the LCD screen (0.100 in).
      • Remove the C-shaped plate from the side of the LCD screen.
      Pregunta a FixBot
      Agregar Comentario
    2. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 6, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 6, imagen 2 de 2
      • Remove the screw from the top-right of the LCD screen (0.098 in).
      • Remove the L-shaped bar from the right of the LCD screen.
      Pregunta a FixBot
      Agregar Comentario
    3. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 7, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 7, imagen 2 de 2
      • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
      Pregunta a FixBot
      Agregar Comentario
    4. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 8, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
      • Be gentle. This ribbon should stay attached to the screen.
      Pregunta a FixBot
      Agregar Comentario
    5. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 3 de 3
      • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
      • Use the tweezers to lift this ribbon.
      • Use the tweezers to gently peel this ribbon from the one underneath it.
      Pregunta a FixBot
      Agregar Comentario
    6. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 10, imagen 1 de 1
      • The LCD screen should now be removed.
      Pregunta a FixBot
      Agregar Comentario
    1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Flash Assembly: paso 11, imagen 1 de 1
      • Remove the screw located on the side of the camera (0.072 in).
      Pregunta a FixBot
      Agregar Comentario
    2. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 12, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 12, imagen 2 de 2
      • Use the spudger to remove the lens ribbon from the circuit board.
      • Use the spudger to lift the ribbon.
      • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
      Pregunta a FixBot
      Agregar Comentario
    3. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 13, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 13, imagen 2 de 2
      • Disconnect the flash assembly ribbon.
      • The flash assembly ribbon is located underneath the lens assembly ribbon.
      Pregunta a FixBot
      Agregar Comentario
    4. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 14, imagen 1 de 1
      • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
      • Be careful when taking out the capacitor. It could shock you.
      Pregunta a FixBot
      Agregar Comentario
    5. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 15, imagen 1 de 1
      • The capacitor should now be removed.
      Pregunta a FixBot
      Agregar Comentario
    1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Camera Lens: paso 16, imagen 1 de 1
      • Remove 4 screws from silver plate (0.106 in).
      Pregunta a FixBot
      Agregar Comentario
    2. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 17, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 17, imagen 2 de 2
      • Use spudger to lift the second lens ribbon.
      • Remember the first ribbon was removed while taking out the flash assembly.
      Pregunta a FixBot
      Agregar Comentario
    3. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 18, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 18, imagen 2 de 2
      • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
      Pregunta a FixBot
      Agregar Comentario
    4. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 19, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 19, imagen 2 de 2
      • Remove the lens.
      Pregunta a FixBot
      Agregar Comentario
    5. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 20, imagen 1 de 1
      • The camera lens should now be removed.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
19 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
Miembros de 3
96 Guías creadas
1Guía Comentario
How do you CLEAN the lens?
Christian - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 48
Ultimos 30 días: 205
Todo El Tiempo: 24,373
