Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Canon EOS Rebel XS Top Panel
Qué necesitas
  1. Disassembling Canon EOS Rebel XS Top Panel, Latch Side Cover: paso 1, imagen 1 de 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Top Panel: paso 2, imagen 1 de 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Top Panel, Disassembling Canon EOS Rebel XS Front Cover: paso 3, imagen 1 de 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Top Panel: paso 4, imagen 1 de 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Top Panel, Back Cover: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Disassembling Canon EOS Rebel XS Top Panel: paso 6, imagen 1 de 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Disassembling Canon EOS Rebel XS Top Panel, Top Panel: paso 7, imagen 1 de 1
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Disassembling Canon EOS Rebel XS Top Panel: paso 8, imagen 1 de 1
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. Disassembling Canon EOS Rebel XS Top Panel: paso 9, imagen 1 de 1
    • You can use your fingers to pull the top panel of the camera.
Conclusión
Una persona más ha completado esta guía.
Daniel Bussone
Miembro Desde 01/28/11
1,268 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 3-41, Regan Winter 2011 Miembro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
Miembros de 2
21 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 28
Todo El Tiempo: 4,294
