Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Canon EOS Rebel XS Front Cover
Qué necesitas
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: paso 1, imagen 1 de 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  2. Disassembling Canon EOS Rebel XS Front Cover: paso 2, imagen 1 de 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
    Pregunta a FixBot
    Agregar Comentario
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: paso 3, imagen 1 de 1
    • Remove three medium length screws from the bottom of the camera
    Pregunta a FixBot
    Agregar Comentario
  4. Disassembling Canon EOS Rebel XS Front Cover: paso 4, imagen 1 de 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Daniel Bussone
Miembro Desde 01/28/11
1,289 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 3-41, Regan Winter 2011 Miembro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
Miembros de 2
21 Guías creadas
3Guía Comentarios
This should be labelled: Easy.
tjt263 - Contestar Compartir
Okay, there are several steps missing.
This is impossible to follow, there must be several things missing here
Fredrik Sjöborg - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 42
Todo El Tiempo: 5,860
