Saltar al contenido principal
Disassembling Canon EOS Rebel XS Battery Door
Qué necesitas
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: paso 1, imagen 1 de 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Battery Door: paso 2, imagen 1 de 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: paso 3, imagen 1 de 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Battery Door: paso 4, imagen 1 de 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: paso 5, imagen 1 de 1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Disassembling Canon EOS Rebel XS Battery Door: paso 6, imagen 1 de 1
    • Use your fingertip to pry off the external shutter port cover.
  7. Disassembling Canon EOS Rebel XS Battery Door: paso 7, imagen 1 de 1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Disassembling Canon EOS Rebel XS Battery Door: paso 8, imagen 1 de 3 Disassembling Canon EOS Rebel XS Battery Door: paso 8, imagen 2 de 3 Disassembling Canon EOS Rebel XS Battery Door: paso 8, imagen 3 de 3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Disassembling Canon EOS Rebel XS Battery Door: paso 9, imagen 1 de 1
    • Once the grip is loose, use your fingers to remove it from the camera.
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: paso 10, imagen 1 de 1
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
  11. Disassembling Canon EOS Rebel XS Battery Door: paso 11, imagen 1 de 2 Disassembling Canon EOS Rebel XS Battery Door: paso 11, imagen 2 de 2
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
Conclusión
Daniel Bussone
Miembro Desde 01/28/11
1,251 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 3-41, Regan Winter 2011 Miembro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 4,987
