Saltar al contenido principal
Disassembling Breville BKC600XL Coffee Brewer Head
Qué necesitas
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: paso 1, imagen 1 de 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: paso 1, imagen 2 de 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: paso 1, imagen 3 de 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: paso 2, imagen 1 de 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: paso 3, imagen 1 de 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: paso 3, imagen 2 de 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: paso 3, imagen 3 de 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Conclusión
Una persona más ha completado esta guía.
Antonio
Miembro Desde 09/26/12
120 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Propen Fall 2012 Miembro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Miembros
6 Guías creadas
2 comentarios
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Contestar
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 4,149
