Saltar al contenido principal
Disassembling BlackBerry 8820 Outer Casing
Qué necesitas
  1. Disassembling BlackBerry 8820 Outer Casing, Disassembling BlackBerry 8820 Outer Casing: paso 1, imagen 1 de 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. Disassembling BlackBerry 8820 Outer Casing: paso 2, imagen 1 de 2 Disassembling BlackBerry 8820 Outer Casing: paso 2, imagen 2 de 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. Disassembling BlackBerry 8820 Outer Casing: paso 3, imagen 1 de 2 Disassembling BlackBerry 8820 Outer Casing: paso 3, imagen 2 de 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. Disassembling BlackBerry 8820 Outer Casing: paso 4, imagen 1 de 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. Disassembling BlackBerry 8820 Outer Casing: paso 5, imagen 1 de 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
Conclusión
Una persona más ha completado esta guía.
ryan
Miembro Desde 04/12/13
44 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-64, Johann Spring 2013 Miembro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 845
