Saltar al contenido principal
Disassembling Beaba Lutin night lamp
Qué necesitas
  1. Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: paso 1, imagen 1 de 3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: paso 1, imagen 2 de 3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: paso 1, imagen 3 de 3
    • The lamp opens up at the base: there are two smaller tabs next to the button, the semi-transparent plasic can be pressed in a bit with a knife, put a bit of paper inbetween to prevent the clip from snapping back. Next go with a knife towards one of the large tabs on the side until one side snaps out. Repeat for other side.
  2. Disassembling Beaba Lutin night lamp: paso 2, imagen 1 de 3 Disassembling Beaba Lutin night lamp: paso 2, imagen 2 de 3 Disassembling Beaba Lutin night lamp: paso 2, imagen 3 de 3
    • Remove the 4 screws (warning: 2x2 different types), out comes the pcb. Detach battery connector at the back.
  3. Disassembling Beaba Lutin night lamp: paso 3, imagen 1 de 3 Disassembling Beaba Lutin night lamp: paso 3, imagen 2 de 3 Disassembling Beaba Lutin night lamp: paso 3, imagen 3 de 3
    • remove two more screws to get at the battery
  4. Disassembling Beaba Lutin night lamp: paso 4, imagen 1 de 1
    • Overview of parts
Conclusión
5 personas más completaron esta guía.
petur
Miembro Desde 07/23/11
508 Reputación
3 Guías creadas
3 comentarios
I think it is easier to open the lamp by pressing the semi-transparent part at the opposite side of the button.
Matthieu Morel - Contestar
How can I open the lamp??? Please post a photo of how are u using the knife because I can't!!!
Alberto Santaella Gallego - Contestar
you need to press the clips inward, the picture shows where the clips are. Slide inbetween and press
petur - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 56
Todo El Tiempo: 3,490
