Saltar al contenido principal
Disassembling Asus W2W-A1 Front Panel
Qué necesitas
  1. Disassembling Asus W2W-A1 Front Panel, Keyboard: paso 1, imagen 1 de 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: paso 1, imagen 2 de 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: paso 1, imagen 3 de 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Disassembling Asus W2W-A1 Front Panel: paso 2, imagen 1 de 1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Disassembling Asus W2W-A1 Front Panel: paso 3, imagen 1 de 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Disassembling Asus W2W-A1 Front Panel: paso 4, imagen 1 de 2 Disassembling Asus W2W-A1 Front Panel: paso 4, imagen 2 de 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Disassembling Asus W2W-A1 Front Panel, Front Panel: paso 5, imagen 1 de 1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
Conclusión
Nolan Schock
Miembro Desde 04/14/14
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-29, Maness Spring 2014 Miembro de Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 322
